BAD vibe
Old Nov 3, 2002 | 03:54 AM
speedfreak's Avatar
Default BAD vibe
Does anybody else get a nasty vibration from the rear under hard acceleration. I noticed that it happens mostly to the right and strait.
I also heard that it was the drivers side axle can some one help it's supposed to go into the shop on Wednesday and i want to tell them what up???
Old Nov 3, 2002 | 04:20 AM
redbullet's Avatar
Max..Pinky had this problem you might want to ask him.
Old Nov 3, 2002 | 05:28 AM
MacGyver's Avatar
Inner CV joint, I believe...
Old Nov 3, 2002 | 02:04 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
make sure the flange bolts on both shafts,and the driveshaft, are tight. i've heard of these backing out on this car.
Old Nov 3, 2002 | 03:10 PM
Pinky's Avatar
Innver CV joint. If your still under warrantee. I can dig up the part number that replaces the entire drive shaft. Inner and outter CV joint. Single part # from Honda. About 500 bucks. If your out of warrantee then you can take the sucker appart and replace the CV joint. Only a couple hundred there.
Old Nov 4, 2002 | 01:40 PM
speedfreak's Avatar
so warranty should cover it huh if thats the proplem.
All of the bolts seem to be tight i checked today.Is there anything else it can be ?
Old Nov 4, 2002 | 01:57 PM
Gernby's Avatar
Former Sponsor
Could you describe the vibration a bit more? I have been experiencing a "vibration" (or thumping, bumping, knocking, etc.) from the rear too. It seems to do it under hard acceleration in 1st gear while turning to the right. I think it is worse when I have less traction (rain). I just assumed it was the limited slip kicking in.
Old Nov 4, 2002 | 04:17 PM
Billman250's Avatar
Top Answer: 1
from what i remember, the driver's side inner c-v joint is probably at fault. if you dis-assemble this end of the shaft and look inside the housing where the three bearings ride, you will probably find the housing is pitted, causing looseness, noise, and vibration. Do a search, someone has an awesome pic of the dis-assembled Shaft, showing the damage.
Old Nov 4, 2002 | 06:38 PM
speedfreak's Avatar
thanks i check it out
Old Nov 4, 2002 | 06:47 PM
speedfreak's Avatar
[QUOTE]Originally posted by gernby
[B]Could you describe the vibration a bit more?
