Balancing flywheel/PP assembly
Old Aug 16, 2009 | 07:51 PM
empowered3's Avatar
Default Balancing flywheel/PP assembly
I am currently replacing my clutch with OEM parts. Do I need to get the flywheel/pressure plate assembly balanced together before re-assembly? Or do the parts come pre-balanced from the factory? I can see the pressure plate only fits up one way.
I have all new components:
Flywheel w/ new pilot bearing
Pressure Plate
Clutch Disc
Throw out bearing
Old Aug 17, 2009 | 07:34 AM
cdelena's Avatar
Normally they are installed as is as the balance is close enough for those components.
Old Aug 17, 2009 | 12:33 PM
SpitfireS's Avatar
Both are balanced independently.
The PP with rivets and the FW with drilled holes.
And IMO the need to be at 9000 / 8000 rpm.
These are an ACT PP - basicaly an OEM PP with a stronger spring and a Comptech FW.
Charper732
May 5, 2017 07:47 PM
vufgew
Mar 2, 2015 11:50 AM
joefish1298
Nov 12, 2013 01:23 PM
riceball777
Oct 19, 2013 05:50 PM
jyeung528
Jan 27, 2008 07:41 AM
