Ball joint problem
Old Nov 18, 2010 | 10:22 AM
harrison1990's Avatar
Default Ball joint problem
Hello guys
Recently working on the suspension works and removed the front upper control arms, after a hard time separating the arms from the hub, the arms finally pop up!
However, when i try to remove the nut that was used to protect the thread of the ball joint, it turns out that the nut is actually rotate with the ball joint body, Ihave to use a plier to hold the body in place to take the nut out
Given the nut will be rotate with the ball joint body, how can i tighten the castle nut when i put the arms back on?? Both of my upper arms are doing the same thing, should i assume it is normal?
Please give me some advise , guys
Thanks you!
Old Nov 18, 2010 | 12:25 PM
sorry for bad description, i will clarify any confusion= ]
Old Nov 18, 2010 | 12:40 PM
HondaRehab's Avatar
Banned
they will spin like you're describing, its normal. Just spray some lubricant on the threads of the ball joint before you put the nut back on.
Old Nov 18, 2010 | 01:17 PM
SpitfireS's Avatar
Lets hope you didn't damage the tapered part of the ball joint with the pliers.
When installing, keep the tapered part clean, on both the ball joint and in the knuckle.
Keep some pressure on the joint towards the knuckle, the tapered parts will "grip" and you can tighten the castle nut to spec.
Start with 49Nm and then tighten further to line-up the castle with the hole.
(max 59Nm according to the manual)
Old Nov 18, 2010 | 02:27 PM
Thank you guys!!!thanks you all of you for letting all of my nerves away!!
i will try to do what you advise!!
btw,, bigbigbigbig thanks!
Old Nov 18, 2010 | 02:55 PM
SgtB's Avatar
I spray the socket and stud clean with brake-cleen. You can tap the top of the balljoint with rubber mallet when it starts to spin. Never-seize the threads.
Old Nov 18, 2010 | 05:07 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Sounds like you were hitting the nut with the hammer.
steven975
Oct 31, 2011 12:39 PM
