Ball Joint Tool
Old Nov 9, 2007 | 07:50 AM
TrackStar's Avatar
Default Ball Joint Tool
Harbor Freight
Will this tool work? I wanna replace the lower rear ball joing in the knuckle.
Old Nov 9, 2007 | 08:50 AM
Ray's Avatar
Ray
http://www.harborfreight.com/cpi/ctaf/disp...temnumber=92882
this is more like it
Old Nov 9, 2007 | 09:18 AM
pemex70's Avatar
I prefer the one suggested by Ray but whatever you do DONT use a fork like this one:
Tie Rod Separator
It kills the ball joint.
Good luck!
Old Nov 9, 2007 | 09:19 AM
114_ap2's Avatar
http://www.harborfreight.com/cpi/ctaf/Disp...temnumber=46821
this is what i use, only because i never have any luck with ball joint removers,
ball joint+me=
Old Nov 9, 2007 | 09:25 AM
TrackStar's Avatar
I was looking at the 1st one because I want to be able to press the ball joints in. Will this handle the job?
Old Nov 9, 2007 | 09:26 AM
pemex70's Avatar
ball joint+me=
Ha! The multi-purpose tool!
That should be incorporated into the swiss army knife
Old Nov 9, 2007 | 10:12 AM
IlleztImportz's Avatar
Old Nov 9, 2007 | 10:18 AM
RACER's Avatar
[QUOTE=TrackStar,Nov 9 2007, 11:25 AM]I was looking at the 1st one because I want to be able to press the ball joints in.
Old Nov 9, 2007 | 10:29 AM
chillout18's Avatar
if they are broken already just use the fork....like racer said they dont have to be press in I just used my airgun and they went in when you tighten down the
Old Nov 9, 2007 | 10:38 AM
Swiftoy's Avatar
What you need is a BFPB(BIG F****N PRY BAR). When I had to remove my diff for gears this is what my brother inlaw brought to use who is an ex mechanic, it is basically about 3 feet long with a flat slightly curved end the other is pointed and it is about an inch in diameter or more. Both ball joints were done in less than a minute. If you saw how easy this was you would crack up.
and no gouged boots.
Swiftoy
