Battery leaking problems
Old Jul 28, 2008 | 11:51 AM
S2kSmiles's Avatar
Default Battery leaking problems
Hi,
Has anyone else had this problem?
I have had two batteries crack and leak acid all over the engine bay. We have cleaned it up twice and I would rather not go through this again. The 2nd battery that cracked was an interstate battery and the first one I can't remember the brand. Is this because of bad batteries or from the brackets that secure the battery? Is the OEM battery hardier? I never had this problem when the OEM battery was in place. Also, I live in California so I don't have any cold issues.
I do autocross alot but have not had this problem until recently.
Thanks,
Kathy
Old Jul 28, 2008 | 11:59 AM
Togobox's Avatar
mine oem battery cracked once. just don't tighten the hold down too too tight.
Old Jul 28, 2008 | 12:05 PM
SheDrivesIt's Avatar
Do you have the heat shield in place between the battery and the engine? Engine heat could be cooking the plastic case.
Old Jul 28, 2008 | 12:20 PM
Togobox's Avatar
or the battery's overfilled
Old Jul 28, 2008 | 02:48 PM
Slows2k's Avatar
Check to see if the alternator is overcharging. Much over 15V cooks batteries
Old Jul 28, 2008 | 07:57 PM
S2kSmiles's Avatar
Yes I do have the heat shield in place. It had to be repainted though due to the acid.
chung
Apr 9, 2013 08:59 AM
Triple-H
92
Apr 13, 2011 11:06 AM
black2000
Jun 18, 2009 10:23 PM
Purple Haze
May 16, 2006 02:44 PM
CoralDoc
Jun 25, 2002 12:33 PM
