Bearing Separator?
Old Feb 1, 2007 | 03:13 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I take it you have the hub out already, and one inner race is still pressed on the hub?
Have someone warm the race with a torch while prying upward pressure at 6 and 12 oclock. Hold pressure, THEN heat while holding pressure.
You don't even need to get it that hot. The race will grow and jump upward enough to make room for the separator.
Old Feb 1, 2007 | 03:50 PM
fperra's Avatar
Yes, everything apart except the inner race. I'll give your heat trick a try tomorrow. Thanks.
Old Feb 1, 2007 | 05:17 PM
Slows2k's Avatar
Heat wil do it, No problem. So will cutting the race with a cutoff wheel and striking the race with a big chisel. You may catch some shrapnel though. The chisel cracks the race and it slips right off.
Old Feb 1, 2007 | 06:45 PM
fperra's Avatar
By the way, I'm talking about the front wheel bearing. When I changed the rear ones last year I didn't have any problem.
Old Feb 1, 2007 | 07:20 PM
Slows2k's Avatar
Same procedures work on both.
Old Feb 2, 2007 | 02:28 AM
Billman250's Avatar
Top Answer: 1
Yup cut off wheel works too. Cut through the race 90% and the rest will easily crack and relieve the press-fit.
Old Feb 2, 2007 | 02:49 PM
fperra's Avatar
The heat trick worked like a champ. Thanks Billman.
G4Z808
Mar 15, 2019 07:53 AM
dragonash
Mar 29, 2016 06:26 PM
gbaker
Jun 27, 2012 04:07 PM
B.Money
Mar 25, 2011 07:48 AM
Kaolinte
Oct 20, 2005 03:54 PM
