Beaten Up Oil Consumption
Old Aug 16, 2002 | 03:26 AM
BryanS2k's Avatar
Default Beaten Up Oil Consumption
My car is a 02 and has 2200 miles on it and so far has eaten up one quart of oil. Is this normal? Seems a bit too much. I've been monitoring the oil level weekly and searched the threads.. I know s2k's eat oil but a quart in less than 3k miles? Do you think I should contact the dealer about this?
Bryan
Old Aug 16, 2002 | 04:12 AM
cdelena's Avatar
It is not yet fully broken in and there is nothing the dealer can do. Try getting more miles on it, especially some under varying loads (60 - 100 on the highway), and see where you are at 5k - 7K miles.. it should stop consuming oil.
Old Aug 16, 2002 | 04:28 AM
GeorgeP's Avatar
I have 2300 miles on mine. I Have used about 1/3 of a quart. Make sure you allow a few minutes for the oil to drain back down into the block before you check it or you will get a low reading.
Old Aug 16, 2002 | 07:11 AM
Gernby's Avatar
Former Sponsor
If you VTEC allot, you will use more oil than if you don't VTEC. I have over 11K miles on mine, and I still use oil, especially when I autocross.
Old Aug 16, 2002 | 08:02 AM
nycbads2k's Avatar
Spammer
Your car will use more oil in the first 5-7k miles. this is normal according to honda while the car "breaks in'. Just monitor your oil level and keep it between the xxxxx w/10w30. change it at 3,750 and make sure you use 10w30. I just had this experience so this is how i know. Be sure u use at least 5.5 qts no more no less. check your oil level at every other full tank at least.
good luck
wang_uk
Jun 14, 2007 06:56 AM
yoweichang
Mar 11, 2002 08:55 AM
Archon
Jan 5, 2002 10:38 AM
txst
Apr 19, 2001 12:46 PM
S2K_Spain
Nov 19, 2000 07:51 AM
