Bent valves - Damage?
Old Jun 30, 2007 | 07:39 PM
WPRAX's Avatar
Default Bent valves - Damage?
I am looking at picking up a 2000-S and was given some information i'm kind of leary of. So I thought I'd get this forums opinions. I was told that the engine on said car failed a compression check after a check engine light came on. I was told that after investigating the dealership had to replace bent valves, shave the deck, and some other minor head work, but that the pistons looked great. I'm no mechanic - but when valves get bent isn't there ussually damage to the pistons also? What would cause valves to bend but not cause piston damage? Just overrevving it?
Thank you for your help. I don't want to pick up a lemon. I want a good representation of the S
Old Jun 30, 2007 | 07:54 PM
IcebergS2000's Avatar
Just my advice... Don't buy it! you will always be worried about something being wrong any time you hear a weird noise... you will sleep better at night
Old Jun 30, 2007 | 08:22 PM
vspc2nr's Avatar
imo, buy it dirt cheep
Old Jun 30, 2007 | 08:25 PM
jasonjm's Avatar
That car is worth 10k :-)
If higher stay away.
Run away actually!
Old Jun 30, 2007 | 09:30 PM
negcamber's Avatar
I've seen a car just recently with 2 bent valves...the piston tops were barely nicked...definitely not bad enough to worry about.
Old Jul 1, 2007 | 04:46 AM
WPRAX's Avatar
Thank you all for your input
bosshog
Oct 19, 2005 10:58 AM
VeilsideAP1
Oct 17, 2004 08:51 AM
w00gie
May 21, 2004 08:08 AM
John MI blk/blk '01
Feb 20, 2002 01:37 PM
nwk00
Dec 8, 2000 03:42 AM
