best method to remove 6mm hex from driveshaft?
Old Mar 29, 2008 | 05:08 PM
SimbaDogg's Avatar
Default best method to remove 6mm hex from driveshaft?
i'm hearing liquid wrench is probably the best way to loosen those bad boys up. should i try a little heat as well? just looking to get this done w/out stripping those stupid hexes
Old Mar 29, 2008 | 05:21 PM
SIIK2NR's Avatar
Liquid wrench
Bang them hard a couple of times
Tap them loose with a breaker bar. Slow constant pressure will strip them for sure.
Old Mar 29, 2008 | 05:30 PM
SimbaDogg's Avatar
ok, im going to give that a shot..and ill pull out my heavy hammers
Old Mar 29, 2008 | 05:46 PM
SimbaDogg's Avatar
never used liquid wrench before actually...how long should i let it sit beforei start to do work?
Old Mar 29, 2008 | 06:20 PM
Sideways's Avatar
It's not absolutely necessary to use liquid wrench. A high quality hex wrench with the ball shaped end is useful. Tap it with a hammer to break it loose. As mentioned above you will destroy the wrench or bolt or both if you just add tension. Hit it with a hammer lightly to break it loose.
Old Mar 29, 2008 | 06:27 PM
S2KPUDDYDAD's Avatar
You can use liquid wrench or PB Blaster 24 hours before you start the job. Removing them is not that bad, just use a good quality hex wrench. You can hit them as suggested but, before you do try to remove as is. I only use a 6 inch long L shaped Allen to remove and have not had a striped one yet.
Good luck
Old Mar 29, 2008 | 06:29 PM
Sideways beat me to it
Old Mar 29, 2008 | 06:36 PM
SimbaDogg's Avatar
Good luck
i should really let it sit for 24 hours? one of them came out before i used the liquid wrench, but the others still seem more than stubborn, and i've been using my hammer and tapping it. but still sitting there very stubborn. i'll just let it sit for a lil longer and hope for the best
Old Mar 29, 2008 | 07:44 PM
SimbaDogg's Avatar
yeah...i'm just gonna let this sit over night, havne't made any progress in the last hour, and i'm still 1/6 of the way there. hopefully things go a little bit better in the morning
Old Mar 29, 2008 | 08:12 PM
SOHCmyDOHC's Avatar
try smacking it to tighten it a little bit then smack it to loosen it.
