Best Source for crush washers?
I've needed to change my differential fluid for a month or so now, but my dealer didn't have the crush washers in stock. I ordered them, but they don't know when they will come in. I've looked at a couple different online suppliers, including HandA, Hondapartsnow, and thehondapartsstore and all want about $10 shipping for less than $2 worth of washers that you could ship for the cost of a first class stamp! I know it's only $10, but paying that much for shipping on two flimsy washers pisses me off, is there a better source to use with more realistic rates? Or should I just throw a couple extra things in the order to get more stuff for my shipping $$$?
if you have your old one on hand you can try to match one up at a local auto parts store, they are usually kept where they sell the generic oil drain bolts.
If you are in a bind you can re-use the existing washer if it is in decent shape and still have some thickness to it. They last quite a while and being copper they deform to the proper shape with each use.
When I bought my car the washer was thinner than paper and was fused to the fill bolt, it must have been re-used about a dozen times perhaps never replaced since leaving the factory, and it still was not leaking. I would not have an issue re-using them 2-3 times if needed. In fact I have re-used my current one twice now because it is still in good shape, despite me having some spares on hand.
order a large quantity, they are cheap and a necessity for fluid changes. I've never heard of a dealer not having crush washers in stock
Buy here: http://www.pegasusautoracing.com/pro...p?Product=3241
.Buy here: http://www.pegasusautoracing.com/pro...p?Product=3241
My dealer does not carry the copper crush washers like the one on the diff, I have to order them in, they only seem to carry the ones for the oil drain bolt. Heck they don't even carry the pcx oil filter in stock , they have to be ordered in. They re-use crush washers and use a generic smaller size oil filter if an s2k should come in unexpectedly for fluid changes, dumb setup.
putting on my flame suit...
honestly... once i used a washer i flip it over and put it back on and tq it down,
then replace it.
napa has crush washers for diff oil and tranny and there cheap,
but i always forget where i put them so i flip it
then replace it.
