Best Source for crush washers?
Do you need a crush washer for the fill plug, drain plug, or both? I'm not 100% certain, I'd have to check when I get home, but I thought the diff drain plug washer was the same as the engine oil. Can anyone verify?
My recommendation: If you find yourself at a Honda dealer that does not stock the correct filters, washers and fluids for routine maintenance for a S2000, leave immediately! This is nonsense, so what other short cuts are they taking during the service?
Umm, I think one of the Trans washers is the same as the oil. The diff bolts are bigger if I remember correctly.
When I got my car, I had the parts dept at the dealer order 10 of each for the trans and diff, got them a week later, and never had to worry about washers since. That was the cheapest option then, and I'd imagine its the same now.
And yeah, I only need the washers for the diff, which at least one (the drain bolt) is a different size than the transmission/oil bolts. Quite frankly, given that Honda doesn't make an OEM diff fluid, I don't know how the Honda dealer does diff fluid changes anyways.
I'll just order a couple extra parts from HandA to make the shipping cost more reasonable; I'll stock up on some stuff, and I was thinking of buying this to keep in the car anyways.
Actually...just called them. They got them in. Nice of them to call
DaPhatty
Aug 25, 2015 02:29 PM
JimiChanga
May 1, 2008 09:34 AM
steven975
Jun 8, 2005 09:09 PM
