Best trans and dif fluid for '02 with 30k miles
Can't find the owners manual either in the car or online I guess.
Honda has put the S2000 owners' manuals on line. This is a link to the 2002 model.
Honda manual transmission fluid is OEM and what I use although I'm considering an Amsoil (sic?) oil later this spring based on recommendation here.
The differential requires hypoid gear oil, not Honda differential oil which is for FWD cars. I'm using the highly regarded Lubrication Engineers LE-"something" (someone or even a search here will reveal the number). Not cheap but you don't need much.
HTH,
-- Chuck
HTH,
-- Chuck
Simple...
OEM Honda MTF for Trans
Mobil 1 Synthetic Gear Lubricant for Diff; 75w-90 or 75w-140 (both work good)
freq (01-30-2018)
