Big Time Problem
Ight, so heres the deal..
I removed my stock airbox as instructed, installed the SRI, but discovered there is no slot in the aftermarket intake to support the Intake Air Temp sensor, but that shouldn't matter as long as its plugged up, so I reset the battery, then cranked her up, she immediately threw a CEL and AND the VSA/VSA off lights, why the he** would it throw a VSA light when all the sensors are correctly plugged back in, 99% sure of that
so, I reinstalled the stock airbox and plugged up all the correct sensors, etc....
I drove it around for 5 minutes or so and the lights still stayed on, I've reset the battery, positive and negative sides, probably ten times now and still no luck, a few Honda buddies of mine looked it up and down and couldn't see what was wrong
I'm VERY OCD and lights being on definitely bothers me, especially when I don't know why the lights are on
any clue as to why shes throwin codes, this is killin me!
But have you considered this
7. ECM logic/SSD mode. The ECM/PCM performs several functions after the key is turned off and removed. You must wait at least 15minutes after the key is turned off before unplugging the PCM. If you unplug the PCM while it's performing the SSD (self shut down) tests you can permanently damage the PCM
https://www.s2ki.com/forums/index.php?showtopic=340163
Originally Posted by mikey k,Jun 9 2007, 05:21 PM
billiardboy904
Aug 3, 2018 08:38 AM
