Billman's coolant bleed
Old Jan 4, 2023 | 12:08 AM
  #121
S2000@9k's Avatar
Originally Posted by windhund116
Key is to park the car on a slight incline. Front end on the "up" side. This helps get the last bit of bubbles out of the coolant system.
It took me 30 minutes, running and revving at idle, to get rid of the last bubbles.
yep agreed front of the car is best jacked up on jackstands - we raised the height of the jackstands from minimum to about half way of the full range.
Old Jan 4, 2023 | 01:01 AM
  #122
NICODON's Avatar
I have used the billman bleeding procedure a few times now on level ground. The results have always been awesome! When complete, I can’t hold my hands in front the heater vent for more than a few seconds. I literally feel like me hands will be Burnt!
Old Jan 4, 2023 | 01:16 AM
  #123
S2000@9k's Avatar
Another thing I forgot to mention - does anyone think it makes a difference if my car was parked up for 18 months (for restoration) with coolant drained out and radiators removed ?
Old Jan 4, 2023 | 03:55 AM
  #124
B serious's Avatar
Originally Posted by S2000@9k
Just to clarify- do you just turn the heater temperature to max hot but do NOT actually turn the heater itself on and leave the car idling by itself and let the funnel bleed out the remaining air - no need to mess with bleeder nipple ? And I assume you turn the heater on to see if it’s ‘hot’ to know if all the air is bled out?
I close the bleeder nipple after I see a full stream of coolant. I clean up the coolant in that area before starting the car. I never touch the bleeder again after that step.
Turn the heater to full blast when you turn on the car.
No. It doesn't matter.
Old Jan 4, 2023 | 07:40 PM
  #125
treimche's Avatar
Look and make sure your heater control cable is physically moving the little valve on the heater hose all the way. You could have someone turn the knob from hot to cold and back and make sure it’s not binding or getting stuck.
Old Jan 4, 2023 | 09:37 PM
  #126
S2000@9k's Avatar
yep checked that and yes when on full hot the cable pushes outwards and the valve opens all the way.
something else came to mind though - would it be a problem for bleeding the air out, if the new thermostat was fitted incorrectly?? ie. with the little hole on the thermostat on the lower side instead of at the top like it should be - I’ve tried bleeding it that many times without success- now I’m thinking there must be something else
Old Jan 5, 2023 | 01:03 PM
  #127
treimche's Avatar
Maybe post a video of how you're doing the bleeding process so we can see? I have also used this method a bunch of times and it worked perfect.
Old Jan 6, 2023 | 12:58 AM
  #128
S2000@9k's Avatar
Yes a lot of people have tried this method and swear by it - but I presume most of them won't have had their car on ramps for 18 months with all coolant drained with radiators off. Also I have AC fitted which I presume has no impact on bleeding the coolant / heater temps - all the gas is empty at the moment in the AC system.
I can video from the point of having topped up with coolant - via funnel in situ and half full - bleeder nipple open until coolant emerges and then closed off - engine started up with heater on full hot and max fan speed - till cooling fan has kicked in once - and starting the first cycle of opening bleed nipple and seeing what comes out 30 secs max - squeeze upper rad hose before closing bleed nipple off - repeat again with 2 mins idling.
Old Jan 6, 2023 | 05:50 AM
  #129
S2000@9k's Avatar
Tried uploading a video but file size is limited on here - I’ll try uploading to YT and posting a link.
Old Jan 6, 2023 | 06:59 AM
  #130
engifineer's Avatar
I highly recommend getting a Lisle funnel for this. They work great. The last time I had to bleed mine I just used the funnel. Still do the first steps as Billman explains, but then you just fill up the funnel, keep it running, check the heat like he says, but the funnel is a great assistant for this and will help you get it bled.
