? on bleeding brakes
Old May 3, 2004 | 12:57 AM
s-duces's Avatar
Default ? on bleeding brakes
What's the order on bleeding your brakes? I heard furthest from the master brake cylinder. Is that true?
Thanks,
Jack
Old May 3, 2004 | 01:52 AM
Ludedude's Avatar
Administrator
Honda recommends (contrary to conventional wisdom) that you start at the closest wheel (drivers front) and work clockwise from there.
Old May 3, 2004 | 10:09 AM
allenheathdj's Avatar
so that would be front drivers, then front passengers, rear passenger, and rear driver...
Old May 3, 2004 | 10:26 AM
TrueDrezzer's Avatar
Any idea why? I've been doing this clockwise bleeding procedure for the car, but I've asked Honda techs and they all say "furthest to closest." Yikes!
///Robin
Old May 3, 2004 | 12:23 PM
Ludedude's Avatar
Administrator
Yep.
I have no idea why they recommend that order for the bleeding but it's clearly marked that way in my service manual (I just double checked).
Old May 4, 2004 | 08:09 AM
Hockey's Avatar
[QUOTE]Originally posted by TrueDrezzer
..... but I've asked Honda techs and they all say "furthest to closest."
Old May 4, 2004 | 01:59 PM
SOHCmyDOHC's Avatar
If the brake system are setup up the same as an EG/EJ2 then the fronts and the rears are on different "systems" so to say. Fronts are one system and rears are another. Don't ask me why they did this but that is how my EJ2 is setup.
Old May 6, 2004 | 06:51 AM
Even if the car has different front / rear systems, wouldn't it make sense to start bleeding from the passenger side of the car?
///Robin
Old May 6, 2004 | 08:44 AM
Sideways's Avatar
///Robin
Why?
Old May 6, 2004 | 06:49 PM
Road Rage's Avatar
The manual says LF> RF>RR> LR. What is the point of dispute? Honda knows what it is doing - maybe they found conventional wisdom did not jibe with how and where trapped air tends to accumulate in this car.
tjhmortimer
Feb 5, 2013 08:12 AM
Dracoro
Jul 31, 2011 09:15 AM
6mmbr
Aug 20, 2009 06:36 PM
stealthx32
May 24, 2008 03:03 PM
1SilentSleeper
Jul 18, 2007 08:10 AM
