Blinking CEL + Harsh Car Vibration?
Old May 31, 2009 | 08:01 PM
GpLhenS2000's Avatar
Unhappy Blinking CEL + Harsh Car Vibration?
I have an 01 with about 105k miles. And tonight as I was going home from work, the car at first idled roughly then the CEL popped and blinked for a while. I immediatley parked the car and checked the Oil and though its low, its not under the Minimum mark line.
Im going to have it towed at a repair shop nearby, but do you guys have any idea what it could be?
BTW, there's no knocking or eweird noises coming from the engine other than the rough idle/vibration the car makes.
Old May 31, 2009 | 08:09 PM
fatjoe10's Avatar
That blinking CEL indicates severe misfire with the potential to damage the catalytic converter. Good move on having it towed.
Old May 31, 2009 | 08:13 PM
[QUOTE=fatjoe10,May 31 2009, 08:09 PM] That blinking CEL indicates severe misfire with the potential to damage the catalytic converter.
Old May 31, 2009 | 10:06 PM
bump guys
Old May 31, 2009 | 10:16 PM
CKit's Avatar
Any recent mis-shifts?
Sometimes it can be a bad coilpack or spark plug. Sometimes the spark plug can vibrate loose and blow out the top of your head... ask me how I know....
If the car was nearby, I'd pull the coilpacks and plugs as an easy first step. You should of course, also check the CEL code.
Old May 31, 2009 | 10:27 PM
pemex70's Avatar
it happened to me once on an onramp, toward the end of it the road had a slight drop and well with lowered cars and stiffer suspension it is sensitive, i hit it and the cel blinked n the car was shaky.
pulled over n shut it off. looked around and took out the plugs and put it back together, same problem. checked the hoses, cables, wires...nothing.
...until i checked the injector harness, one of the clips wasnt in all the way and was misfiring cyl 1...damn! thats all it was. it did sound like a boxer engine though.
check the plugs and injector harness.
GL
GoKaart
Jun 23, 2017 01:08 PM
saving4one
Jul 3, 2016 09:10 AM
vasquezgno
Nov 5, 2013 06:54 PM
maranelloboy05
May 15, 2013 07:03 PM
shinigamiz
Jul 11, 2008 08:45 PM
