Block Boring questions
Hey guys,
i recently bought a spoon stroker kit, and was un-aware they supplied the .25 oversize pistons. So my Block is at a boring place now, but he has said he is hesitant to machine it cause he's unsure on the cylinder walls.
Could anyone answer these questions:
What metal is the cylinder wall made of?
how thick is it, and is it safe to machine this back .25mm?
If it CAN be machined back .25 and I am thinking of possibly running some FI later on, be it around 10psi, Will the wall I have remaining be strong enough for this or will I have to sleeve it if I wanna go FI?
Also if anyone can answer what kind of rings are in the SPOON 2.2l kit? and any recommendations of a matching Sleeve (brand/material) that these rings would bed in well with.
Cheers ^^
Cheers ^^
You will need to hone with a Diamond hone and special coolant. 0.25mm can be done with a hone only.
If you want to send your block to Sydney I can get it done for you with a stress plate as well.
Otherwise, ask around the machine shops. The later generation of Holden and Toyota motors use similar bores so some machine shops are starting to upgrade their equipment,
See my F24 thread on pictures of how thick the FRM was on my block. Pictures show the bores after honing to +.25mm pistons.
F24C FRM build
Chris.
F24C FRM build
Chris.
Guzzie
Nov 27, 2008 03:14 AM
