blower motor resistor
Old Aug 11, 2012 | 11:11 PM
wickwirew's Avatar
Default blower motor resistor
My AC stopped has stopped working. The compressor will click on for only a split second and the blower wont turn on at all. Ive read around and it sounds like the blower motor resistor, but I want to get some feed back before I go and purchase a new one. Has anyone had the same problem and where is the blower motor resistor located as well?
Old Aug 13, 2012 | 09:22 PM
wickwirew's Avatar
anything??
Old Aug 14, 2012 | 07:43 AM
s2klariat's Avatar
Check all fuses associated with the A/C system before buying any parts. Could be as simple as a blown fuse.
Old Aug 14, 2012 | 10:24 AM
bdo's Avatar
bdo
Since nobody else has posted: Have you tried max spped? Not sure if this applies with our electronic controls, but with a traditional resistor system max speed will sometimes work with a blown resistor since it sort of bypasses the resistor.
Old Aug 14, 2012 | 02:29 PM
wickwirew's Avatar
yea it works on high thats why im kind of confused. Ive heard of other hondas doing the same thing as mine and it turned out to be the resistor
Old Aug 14, 2012 | 05:34 PM
downloader's Avatar
when the resistor goes bad you only have one speed (high) so your blower will only work on high. The A/C thinks the system is off in any other speed than high.
Old Aug 15, 2012 | 09:11 AM
wickwirew's Avatar
Ok i just wanted to make sure cause I read about an accord doing the same thing and he said it was the resistor. As of now my bet is the low pressure switch or just the blower motor. Thanks though for all the input!
Old Aug 15, 2012 | 01:21 PM
bdo's Avatar
bdo
It's the resistor.
Old Aug 15, 2012 | 11:06 PM
wickwirew's Avatar
bdo are you sure, because the AC doesnt work even on the high setting
Old Aug 16, 2012 | 07:17 AM
bdo's Avatar
bdo
I thought you said it worked on high - guess I totally misunderstood! So no, now I'm not sure at all, sorry for the confusion.
