Blown spark plug
Old Dec 18, 2011 | 06:34 AM
hariku821's Avatar
Default Blown spark plug
http://www.youtube.com/watch?v=kLd_W...ature=youtu.be
I had the car on a dyno with a lot of knowledgeable people around a few months ago and no one noticed anything wrong and my car put down 205whp while other s2000s normally only put down 185-195 on this dyno.
Last night I had to fill up on gas and checked the oil all was good and I dropped the hood and got in the car and left. As I am going down the highway I notice the hood is not totally closed so I stop open it up all the way and thats when I hear the noise. I looked around for anything banging around anything obvious and couldnt see anything so i drove 15 miles home parked and went to bed. This morning I start the car up and am a little worried about it so I start messing around with it and cannot figure anything out so I decide to look online. When I got back in the car to shut it of I noticed a CEL......
So where do I go from here... Check the CEL would be obvious but can I drive the car 2-3 miles to autozone to get them to check it?
Reading a suggestion in another thread about noise a guy said add more oil even if your stick shows some so I did that even though when warm the oil is near the middle of the reading diamonds.. This stopped the loud marble in a can noise so I took it to a auto parts store to have the CEL read and it showed misfire on all 4 cylinders???
Old Dec 18, 2011 | 08:40 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Dont ever add oil to an engine that doesant need it. If its full, its full. Overfull can do serious damage.
That sounds like a sticking BELT tensioner. run it for a minute without the belt on it, see if the noise goes away.
Old Dec 18, 2011 | 09:45 AM
rob-2's Avatar
That doesn't sound like tct.
How many miles?
Old Dec 18, 2011 | 10:48 AM
hariku821's Avatar
The car is an 03 has 69k miles on it and I haven't had an issue until now...
The knocking noise went away after I added that little bit of oil here are 2 more videos of what it sounds like now...
http://www.youtube.com/watch?v=dBc6dNSxEhg
http://www.youtube.com/watch?v=J3QFGEx3qP8
Old Dec 18, 2011 | 07:26 PM
hariku821's Avatar
So I was going to check the plugs to see if anything was wrong... A bolt on the cover got stripped in the process so I got a drill bit and drilled a pilot hole then used a striped screw remover bit but the bit broke in the bolt. After dealing with that I removed the plugs and found the second plug from the front bumper had been destroyed.. So here are all the plugs..
I do have a nitrous system installed but I have not used it in a year or so ~ 10k miles.. The plugs are one step colder copper(?) ngk plugs I put them in when I was spraying and have just left them in. I also checked the plugs often when I sprayed. This occurred after the last time I sprayed.
I ordered another set of stock plugs they should be in tomorrow but should I even put them in.. what should I do next..
After searching I have found I need to do a compression test and pull the head to check for damage.. fun fun...
Old Dec 18, 2011 | 10:15 PM
CKit's Avatar
Some people have gotten away with electrode tip disintegration without problems if the pieces get spit out without banging around too much. You might be lucky. Compression test is a good first step.
Old Dec 19, 2011 | 03:45 AM
wrecked's Avatar
I just looked at an 03 my friend is interested in buying and when I pulled the plugs to do a compression test, the spark plug in cyl # 1 was damaged like yours but the compression came out perfect with 230psi on all cylinders. It also ran great with the damaged spark plug.
Billman250's Avatar
Top Answer: 1
That plug was loose. Thats why there is carbon above the sealing washer. hows the coilpack?
Loose plugs go lean, overheat and melt off. Mechanics error.
Old Dec 19, 2011 | 03:47 AM
Billman250's Avatar
Top Answer: 1
I think what ever cylinder that plug came out of is going to have a scored cylinder. That would explain the noise.
Old Dec 19, 2011 | 03:48 AM
wrecked's Avatar
I mean, just the ground electrode was broken, I dident realize your center electrode was missing.
