blue smoke
Old Jan 4, 2007 | 05:44 PM
sexycheto88's Avatar
i wasn't charged,
the oil was changed when i bought it 300 miles ago
Old Jan 4, 2007 | 05:49 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Well listen....make sure the oil level is full, then bring it in. Very important.
You bought it used from the dealer?
Old Jan 4, 2007 | 05:51 PM
yeah i'm driving conservativly. i'm gonna call them up and bring it in tomorrow.
but its very scary.
Old Jan 5, 2007 | 08:17 AM
Danfotoman's Avatar
black smoke= normal (for this car)
blue smoke= rings
white smoke= head gasket
any excessive smoke is no good...
what did the dealer say?
Old Jan 5, 2007 | 10:21 AM
slalom44's Avatar
Top Answer: 1
Time for a compression test.
Old Jan 5, 2007 | 12:35 PM
i called and the matiance part is closed for the day.
but gonna go work out early tomorrow and call them at like 10 when they open.
i noticed today i might be crazy but some lose in torque in 1st. idk this car seems to be falling apart lucky i got that warranty
i didn't see the color of the smoke. i hope its just black. i know our cars run a slight bit rich. i hope its not blue. rings can be expensive to fix.
Old Jan 5, 2007 | 02:36 PM
krazik's Avatar
Administrator
hey guys blue smoke isnt' that uncommon. had you been driving hard before or chucked it around any corners? I can make any s2k blow blue smoke easily.
High RPMs (an usually some corners) then suddenly backing out of the gas then getting back on it will make most s2ks smoke.
-Ry
Old Jan 5, 2007 | 03:02 PM
i've had it for 500miles... i've hit it hard a few times. but not drasticly.
but it burnt all of its oil off in 400miles... so theres something wrong.
Old Jan 5, 2007 | 07:43 PM
Avernus's Avatar
so you put it into first going 30? That means you may have had maybe 8 more miles per hour left till the fuel got cut on you. and it should have not been easy to get it into first. I'm just trying to clarify things for myself.
Old Jan 5, 2007 | 09:21 PM
90crvtec's Avatar
I was wondering the same thing. Sounds like somebody started learning to money shift a little early?
