Blue smoke
Old Oct 14, 2008 | 10:31 AM
AndyThomason's Avatar
Default Blue smoke
Sooo usually when my car is cold, and I am leaving my neighborhood or something, I will clutch it when pulling up to my neighborhood exit, and just notice a ploom of blue smoke just filtering out of my exhaust pipe. I have a single exhaust and test pipe if that makes a difference, but I'm just wondering if this is cause for concern. My friend, who is a technician, said it could possibly be bad valve stem seals and that's why it's smoking when the car is still a smidgen on the cold side. I have 103k miles as well. Any thoughts, suggestions? Or possible repairs and prices?
Old Oct 14, 2008 | 10:57 AM
05TurboS2k's Avatar
^ not unheard off.... probably rings, as it heats up the tolerance tightens and it's fine again. I'd just drive it. Not only that but even perfect condition car w/ a test pipe will give a little smoke off when cold.
If it's a lot do a compression/leak down test.
-Greg
Old Oct 14, 2008 | 11:14 AM
chimmike's Avatar
-Greg
smoke caused by a test pipe isn't blue, its going to be black, unburnt fuel burning in the exhaust.
blue smoke=indicative of burning oil somewhere. If you're not in VTEC, you shouldn't be burning oil. I'd get a compression and leakdown test done.
Old Oct 14, 2008 | 11:29 AM
05APdeuce's Avatar
I think your friend is correct thats what happened to my old inregra the valve seals went bad and I always puffed blue smoke
Old Oct 14, 2008 | 11:40 AM
05TurboS2k's Avatar
I'd agree about the smoke color, how sure are you that it's blue? are you seeing this out of your rear view mirror?
I figure your rings are a little worn and your burning a little oil prolly no biggy but I'd just check it out.
Old Oct 14, 2008 | 11:54 AM
chimmike's Avatar
my best indication that it's oil smoke vs. water is 1) it's bluish/white
2) It lingers, doesn't evaporate.
Old Oct 14, 2008 | 12:03 PM
well when i am moving still at 5mph creeping to a stop with my top down and i clutch it and i am bombarded with smoke, that kind of gave me the idea it was bluish/white lol
Old Oct 14, 2008 | 12:24 PM
05TurboS2k's Avatar
^ ok that sounds bad. "bombarded"
Go do a compression test ASAP and post the numbers in this thread please. To keep things simple and comparable KEEP IT FLOORED WHILE TESTING... have the motor at least a little warm, make sure all plugs are out during the test and pull the fuse for the fuel pump. crank it over 4 times and then test the next cylinder.
Cylinder #1 < hopefully you see around 200-228 psi on each.
-Greg
Old Oct 14, 2008 | 12:27 PM
maybe bombarded is the wrong word lol. it's not like "OH MY GOD it's smoking" but its like "hey why is it smoking like that"
i'll see what i can do about getting a compression test done tho
Old Oct 14, 2008 | 02:05 PM
05TurboS2k's Avatar
