Blue smoke vs gray smoke - oil vs fuel
#51
I bought a used head(perfect condition),took it at a specialized machine shop with new ferrea valve guides and oem honda valve seals.After 3 days i took the cylinderhead from the machine shop(the new guides were easy to see) and went to my mechanic.He swapped the "new" head with the original one.I was there all the time,just in case...Unfortunatly,nothing changed.I was sure that the guides were the problem but i was wrong.The thing that drives me crazy is that if i got worn piston rings or worn cylinder walls,how the hell the compression test was fine(3 times checked/225-230 all 4)????
#52
Junky is correct: my F22 had good compression but drank oil. When I took it apart, discovered that the oil control rings were gummed up and stuck in the ringlands, while the compression rings were perfect. This is why I suggested to remove one piston to inspect the rings.
#53
I wouldn't do anything bottom end related with the consumption quoted. Wast of time and money. When you start drinking a quart every 500 miles you got a clear bottom end problem and you will get tired of dumping in oil, changing plugs and cleaning off your rear bumper, so dig into it then or just pick up a lower mile used engine. Until then, drive it like you stole it.
#54
funny thing is, the rear bumper is not more dirty than compared to when the car was new.
i've since got it back up to a quart every 800 miles by mixing in 15w50.
#55
my s was drinking a quart every 350 miles. i still dump in oil. granted, it's no longer my daily driver, which helps a lot.
#56
Thanks all the guys!I don't intend to do nothing with the bottom end.I'll just try the penzoil premium10w30 and hope for a little less smoke at traffic situations.The only solution is a new oem short block from Honda.I'll add a full rebuilt head(new valves,valve guides,seals) and enjoy a brand new motor with zero miles.
#57
How about combining f22 bottom end with jdm f20c head and jdm ecu.I know the 9000 rev limiter is a bit high for the f22 but some guys have done it.Any info for the reliability of a combination like this.I suppose it'll be a real fast motor.
#58
With my f20 ap1 I almost never revved it beyond 8500, there was no point as it stopped making power by then and I was already in the sweet spot for the next gear change by 8000 rpms.
#60
You don't have to remove the engine to swap out piston rings. If you're going to go through the trouble of pulling the head, might as well toss new rings on there while you're in there.
