Bolt for Compressing the Piston on the TCT
Old Sep 21, 2016 | 07:29 AM
super_mut's Avatar
Default Bolt for Compressing the Piston on the TCT
I need to replace all the seals on my TCT as I have a slow weeping oil leak going on. I've already replaced my VTEC seals.
My question is, I would prefer to compress the piston the TCT when it is still on the car before removing the unit. Can I use any 5 x 0.8mm bolt?
I'm assuming the 5 is the bolt head size and the 0.8mm is the thread pitch. Can someone help me confirm this?
Old Sep 21, 2016 | 08:56 AM
windhund116's Avatar
5mm shaft diameter. 0.8mm pitch.
Old Sep 21, 2016 | 10:46 AM
Slowcrash_101's Avatar
it's an 8mm bolt head.
Old Sep 21, 2016 | 10:56 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
5mm is the thread diameter, .80 is the thread pitch. 40mm is ideal length.
Old Sep 21, 2016 | 01:24 PM
s2000ellier's Avatar
i got one from ACE hardware
Old Dec 7, 2016 | 09:40 PM
super_mut's Avatar
I'm bumping this.
I cannot find an 8MM HEAD bolt that is 5MM Diameter / 0.8MM Pitch anywhere
Can someone help clarify this? Thanks.
Old Dec 7, 2016 | 11:54 PM
https://monsterfastener.com/item/tbh-003
Old Dec 8, 2016 | 12:48 AM
flanders's Avatar
It's a standard M5 bolt and I can't see the shape of the head matter, as long as you have some kind of tool to turn it
Old Dec 8, 2016 | 06:21 AM
Chuck S's Avatar
Compressing the unit on the car is not necessary, just unbolt it and all the parts come out. Very slippery, don't drop them. Installation requires a compressed unit. The OEM and Billman TCTs are compressed and held with a pin that's removed once the unit is in place.
-- Chuck
Old Dec 8, 2016 | 10:08 AM
Billman250's Avatar
Top Answer: 1
Bolt head size is of no matter. Can be hex, screw, etc...
