Bolts WAY TOO TIGHT!
Old 03-16-2010, 10:47 AM
Benihana's Avatar
Default Bolts WAY TOO TIGHT!
Hey guys, have the car up on ramps and a jack. Been trying to get the bolts screwed off the beam that restricts me from pulling the exhaust off. Using a 3/8 ratchet on the 10mm and 14mm bolts and they just don't want to seem to budge. I put WD-40 on the bolts, but they still aren't budging. Do I need to upgrade to 1/2 to take these off. Thanks for any responses.
Old 03-16-2010, 10:56 AM
killyougood's Avatar
Use a breaker bar or get a pipe to slip over your wrench to create more torque.
Old 03-16-2010, 11:33 AM
spets's Avatar
use sudden snaps, not steady pressure, to break them lose.
Old 03-16-2010, 11:34 AM
Stvn2k's Avatar
Go to home depot or lowes and pick up some PB Blaster. Spray it on the bolts, let it sit for 15 minutes. Use a heavy hammer to hit the ratchet and hopefully they will loosen up, try not to strip them!
Old 03-16-2010, 11:43 AM
bouford's Avatar
pb blaster or liquid wrench ftw! just soak them good.
you can also use the left over for removing the exhaust mounts
Old 03-16-2010, 11:44 AM
schmittx's Avatar
PB blaster works wonders!
Old 03-16-2010, 11:48 AM
zeroptzero's Avatar
Received 3,390 Likes on 2,461 Posts
3/8 ratchet might be a bit too short, longer bar definitely helps.
Old 03-16-2010, 12:03 PM
r_duff's Avatar
i put pressure with one hand and hit the back of that hand with my other hand. ususally works... dim mak style!
Old 03-16-2010, 12:20 PM
fatjoe10's Avatar
Try a torch to heat things up... never fails me when they refurse.
Old 03-16-2010, 01:22 PM
aresk3b's Avatar
you can use your 3/8 drive.
I usually grab the rubber mallet or a dead shot hammer and hit the end of the ratched.
Fast shot get them loose, steady pressure torque like a big pipe usually are prone to strip the bolts instead of loosing em.
gl
Quick Reply: Bolts WAY TOO TIGHT!
