Bought a used S2000 and the A/C isn't working
Old Apr 27, 2012 | 10:31 PM
bab33face's Avatar
Default Bought a used S2000 and the A/C isn't working
Bought a used S2000 and the A/C isn't working. Investigating the engine bay and found this loose plug
Anyone know what this is for?
Old Apr 27, 2012 | 10:33 PM
bab33face's Avatar
If this has nothing to do with the A/C where should i look next?
The dash button lights up when I turn it on but the air is not cold at all.
Old Apr 27, 2012 | 10:34 PM
deanbayley's Avatar
Get it re gassed?
Old Apr 28, 2012 | 03:21 AM
s2000maniac's Avatar
Originally Posted by deanbayley
Get it re gassed?
You mean re-charged?
Old Apr 28, 2012 | 04:11 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
That's a horn connector.
The system likely has a leak and lost it's charge. Check the connector on the back of the compressor, and any connectors going to the AC lines.
Old Apr 28, 2012 | 08:48 AM
deanbayley's Avatar
No I mean re gassed
deanbayley's Avatar
It's not a battery
Old Apr 29, 2012 | 11:50 PM
YFZ450's Avatar
check the wires and connector going into the condenser can thing in the front of the car.. pretty random but this was a problem i had before i think a sharp rock cut it or something
Old May 1, 2012 | 08:10 AM
bab33face's Avatar
Now I realize the horn is missing.
Anyone know where to look to get my A/C recharged?
Old May 1, 2012 | 08:27 AM
NFRAP2's Avatar
Any repair shop that does AC work can recharge it for you. You could also buy the refrigerant and hose/gauge to recharge it from the parts store. If you recharge it and find that the AC works again (even if only until the gas leaks out) then you know the problem is a leak in the system somewhere and not something mechanical.
