brake bleeding while engine running?
Old Apr 21, 2008 | 11:18 AM
owenxguo's Avatar
Default brake bleeding while engine running?
Just did fluid flush for my Evo, service manual told to bleed with engine running, so you could bleed the ABS pump. I haven't see anyone talk about this for s2k, so wondering if you have to do the same on S or not? Because I have a little bleeding issue with my S, bleeded few time already, padle still going pretty low, almost first 50% has nothing but vacum sound from booster. And while the car running, padle going even lower.
Old Apr 21, 2008 | 11:20 AM
mikegarrison's Avatar
No, there is no need to have the engine running to bleed an S2000. Sounds like you just didn't do it quite right.
I use a pressure bleeder system, and that works great. I have never had good luck with the pedal-pumping method.
Old Apr 21, 2008 | 01:57 PM
owenxguo's Avatar
Do you have to bleed ABS pump seperate?
Old Apr 21, 2008 | 02:03 PM
No.
Old Apr 21, 2008 | 03:11 PM
shotiable's Avatar
i used the pump method... i didnt have problems with that
Old Apr 21, 2008 | 04:55 PM
owenxguo's Avatar
I used have speed bleeder on my stock calipers, they works fine but padle can't be stiff like factory. Either street pads or race pads with rotors.
After stoptech BBK, it's getting even worth, like now, pretty much first 70% is like nothing while running, all you hear is vacum from booster. I used have Earl's solo bleeder, they don't work well, so went back to original bleeders and bleeding with 2 people(while engine running), nothing really different. I will try to bleed again with engine off tomorrow.
Old Apr 22, 2008 | 04:33 AM
TrackStar's Avatar
What system do you use?
Old Apr 22, 2008 | 05:28 AM
Motive Products
Old Apr 22, 2008 | 05:36 AM
TrackStar's Avatar
Thanks I've been looking into one of those.
Old Apr 22, 2008 | 12:31 PM
iam7head's Avatar
mike i recall our abs(or newer honda abs pump) calls for a power on bleed, let me get back to you after i check my manual at home
