brake bleeding while engine running?
Old Apr 22, 2008 | 12:44 PM
mikegarrison's Avatar
Originally Posted by iam7head,Apr 22 2008, 01:31 PM
mike i recall our abs(or newer honda abs pump) calls for a power on bleed, let me get back to you after i check my manual at home
Check the Helm manual.
I've done dozens of bleeds on my car. Never had the power on, never had a problem. As I said, though, I'm using a pressure bleeder.
Old Apr 22, 2008 | 02:08 PM
bam9382's Avatar
is there a DIY for this or brake pads that has pictures??? the one on the DIY page wasnt very helpful for me.. couldnt really visual it without photos... know of a thread? or other site with a good DIY ??
Old Apr 22, 2008 | 03:29 PM
You need pictures to bleed the brakes? I don't understand. What is there to take pictures of?
As for swapping pads, the Helm manual is well-illustrated.
Old Apr 22, 2008 | 06:12 PM
owenxguo's Avatar
Anyone has BBK on their car? Just received my new grassroots motorsports magazine, and there is something about BBK.
Big front calipers also require more fluid volume, which means longer pedal travel and less fluid reserve for when pad fade strikes.
So wondering if anyone here with BBK has the same issue, or it's not about BBK?
update: I am talking about front BBK not all 4 corners.
Old Apr 22, 2008 | 06:59 PM
vspc2nr's Avatar
MIKE!!
I need some help in bleeding my brakes, i can't seem to get my damn "brake" light off since i painted my calipers.
Old Apr 22, 2008 | 07:01 PM
Is the only symptom of a problem that the light on the dash stays on? Maybe it's just that the float in the master cylinder reservoir is stuck.
Old Apr 22, 2008 | 07:06 PM
vspc2nr's Avatar
thats what i was thinking, but do i have to replace the whole assembly?? And it kind of feels a little touchy/slushy at times. I bleed the brakes 4x but cant seem to get out all the bubbles out. I might have to do this when the DAMN weather starts acting like spring.
Old Apr 22, 2008 | 07:15 PM
Not if it's just a stuck float. You can reach in and free it up.
As for trouble getting all the air out, did you use a pressure bleeder or did you use some other system? IMO, the pressure bleeders do a much better job than any other technique (although some folks here swear by "gravity bleeding" as best).
Old Apr 22, 2008 | 07:18 PM
vspc2nr's Avatar
system?? no system, just the ol' wife pump and i bleed technique I tried tapping and dipping my pinkey inside but nothing.
Old Apr 22, 2008 | 07:28 PM
Well, we have now reached my limit for internet diagnosis.
