Brake caliper/bracket torque?
Old Sep 8, 2008 | 07:23 PM
SlidinS2k's Avatar
Default Brake caliper/bracket torque?
I had to remove my rotors to clean them. The brake pads rusted and stuck to them after a wash. (had to break them off) I'm ready to put everything back together but, I don't have correct torque specs.
I've never really needed a Helms, b/c I've always found what I needed on here. Unfortunately, not this time.
From searching,
Front caliper bolts - 24 ft. lbs.
Rear caliper bolts - 23 ft. lbs
For the brackets, I've seen everything from 41 ft. lbs. to 70 ft.lbs.
If someone would so kindly look in the Helms and get me the correct torque specs, I'd appreciate it. MY00.
Old Sep 8, 2008 | 07:28 PM
centralcoastbuc's Avatar
80 lb-ft for 2000 to 2003. This is for the bolts that hold the caliper bracket to the hub.
Old Sep 8, 2008 | 07:34 PM
SlidinS2k's Avatar
Thank you sir.
Pantwone
Sep 29, 2007 09:31 AM
replicah
Jul 20, 2007 12:20 AM
heath389
Sep 16, 2003 06:49 PM
