Brake Fluid
Old Nov 1, 2002 | 07:14 AM
JimmyB's Avatar
Default Brake Fluid
What is the best DOT 4 fluid to use in the S2K?
Old Nov 1, 2002 | 06:32 PM
johnnydev's Avatar
Jimmy, don't know why no one replied to your post. I don't know the answer either, but realize that you are asking for an opinion. And as the saying goes...everybody's got one. Do a search for "brake fluid" or "DOT 4" or something and you will find lots of threads with a wide variety of opinions and I am sure you will find the answer you seek...
jd
Old Nov 1, 2002 | 07:27 PM
Tedster's Avatar
What's your reason for going to DOT 4? Are you planning to take your car to the track, autocross, or just street use?
As I understand it, the primary tradeoffs for brake fluid are cost, lifespan (mainly moisture absorption), and heat resistance (dry and wet boiling points). For street use the stock DOT 3 stuff is cheap, will last for what, two years? without a change, and won't boil unless you drag your brakes down a mountain.
I don't think autocross courses typically have enough hard braking to boil the stock fluid, but I'm sure the experienced cone-dodgers will chime in; I do think many of them use DOT 4 stuff, though.
If you're going to the track, I've found that Ate SuperBlue and Motul RBF 600 are reasonably priced (~$15), will last for six months or so, and hold up pretty well to track use. You can pay a lot more for stuff with higher boiling points, but I believe it will only last a short time.
Old Nov 1, 2002 | 07:28 PM
RT's Avatar
RT
ATE Super Blue seems to work fine ....... good compromise between a high enough boiling point w/o being too hygroscopic.
Old Nov 1, 2002 | 07:31 PM
Tedster's Avatar
Sure, Ray, bust out the ten dollar word.
Old Nov 1, 2002 | 08:16 PM
RT's Avatar
RT
LOL ... who me?
Old Nov 2, 2002 | 06:42 AM
JimmyB's Avatar
Thanks guys,
I was planning on tracking the car, but tore up my neck si I will have to wait until spring. At that time i will go Super Blue for the track. I agree BIG WORD!
myflys2k
May 25, 2009 06:44 PM
myflys2k
Jan 28, 2007 09:05 PM
yoginhima
Jan 16, 2005 10:12 AM
aquatic
Feb 24, 2003 01:27 AM
marclw
Sep 11, 2002 10:25 AM
