Brake Fluid Change
Hey guys. I have an '03 S2000 with 16k on the odometer. I want to change the brake fluid to ATE Super Blue and I can't seem to find a write-up with pictures on this forum. If there is one could someone please point me in the right direction? Thank you very much.
I can't believe you quoted yourself in your sig
Rev has a good tutorial on his page for bleeding and a couple other good ones too...
http://reverendsgarage.net/index.php?conte...leed_brakes.php
Originally Posted by BlackJoker,Aug 11 2005, 10:22 AM
This says how to bleed your system. I'm doing a full flush of the brake fluid and replacing it with new fluid. What would I do different from the bleed write-up?
"In the earlier days, the mechanic would bleed the brakes by having someone pump and hold pressure on the brake pedal as he opened the brake lines located at each wheel. This method of bleeding the brakes is not a recommended procedure for newer brake systems (discussed later). "
Is this true? If it is, I think I should take it to a Honda Specialist here in town to have the procedure done.
The link to this article is: http://www.trustmymechanic.com/brake_fluid_change.htm
James your more than welcome to pay someone else to do the job for you. That's something I have done quite a few times out of laziness.
fwiw this is how I have flushed my brakes before with JP's assistance, pantyraider has done this also, rev (the guys who did the diy page) does it this way, I'm willing to bet mike has also, and many other track junkies have and we're all running aorund w/o any problems. So there is quite a few reliable sources that do it the same way
Originally Posted by mikegarrison,Aug 11 2005, 04:12 PM
I have done the pedal pump method, but these days I use a power bleeder so I don't need a second person.
