brake fluid/clutch fluid
Old Apr 17, 2006 | 02:21 PM
anthonys2k's Avatar
Default brake fluid/clutch fluid
i know i can use the brake fluid for the clutch fluid..but how much should i get..i want to flush my brakes and and clutch fluids..i was going to buy the ATE blue..will one can of that do both or do i need to order 2?
Old Apr 17, 2006 | 02:38 PM
Trip's Avatar
I did this last weekend. Flushed both brake and clutch
used around 250/300ml for the clutch, and around half a ltr for the brakes.
Others will chime in with more accurate #
Old Apr 17, 2006 | 03:02 PM
John_Z's Avatar
I can't rememer the oz but I used 1 large and 1 small bottle of brake fluid when I did the brakes and clutch. I made sure to really flush out the old stuff until the new fluid came out clear.
I had quite a bit of leftover fluid, but I figured I did not want to be in the middle of the job and run out.
If I had to do it again, I could do it with just one large bottle FWIW.
Old Apr 17, 2006 | 03:03 PM
mikegarrison's Avatar
One liter should be enough for both.
Old Apr 17, 2006 | 06:14 PM
gomarlins3's Avatar
I would like to do this as well, but don't know how to flush the clutch. Guess I need to look that up. I've done the brakes before.
Old Apr 17, 2006 | 06:19 PM
Same thing (assuming you used the pedal method). The bleed valve is harder to get to, under the car by the clutch slave cylinder.
Old Apr 17, 2006 | 07:27 PM
gomarlins3's Avatar
^Thank you.
Old Apr 18, 2006 | 07:14 AM
Wisconsin S2k's Avatar
there is a DIY for the clutch fluid in the FAQ at the top.
also 1 liter should be enough for both. you can't "save" the fluid either once you've opened it. discard any remaining fluid when you're done.
Old Apr 18, 2006 | 09:44 AM
John_Z's Avatar
Old Apr 18, 2006 | 10:40 AM
anthonys2k's Avatar
thanks for the info guys
