Brake Light On....
Old Jan 10, 2007 | 12:30 PM
slanguage's Avatar
Thumbs up Brake Light On....
The last couple of days, there are times my brake light is still on when I take off the parking brake, but only for a few minutes and then it goes off. It doesn't always do this though.
The brakes are in good condition, fluid level is proper, no leaks, and had a new brake resevoir, clutch resevoir, and DOT 4 fluid put in 2 months ago. Also, no bad or strong odors.
My guess is that maybe the parking brake needs to be adjusted and/or lubed. That hasn't been done since I've had the car.
How do I adjust the brake? That self adjusting thing is just a bunch of BS if you ask me. Is there any part of the brake setup between the handle and the brake that should be lubricated, and what should I use?
Yes, I did try a search, and didn't find anything that helped me out.
Thanks in advance for any help and/or info
BTW, it's the light on the dash, not the lights on the back of the car
Old Jan 10, 2007 | 01:50 PM
negcamber's Avatar
Interested too...mine does this when it is really cold. I'm guessing the contact to the switch under the center console needs adjusting.
Old Jan 10, 2007 | 02:04 PM
Jay2000's Avatar
Really cold in florida? It is 25 degree's with a 25 mph wind chill here. And that is not cold in relation to some areas. I wish I was there with you.
Old Jan 10, 2007 | 02:17 PM
slanguage's Avatar
Old Jan 10, 2007 | 02:57 PM
negcamber's Avatar
Don't be hate'n...I had to put a jacket on today...dropped below 60.
Old Jan 10, 2007 | 03:14 PM
MadeInTaiwan's Avatar
this happened to me in my Prelude...the e-brake probably needs to be tightened (in my case at least). in the Prelude there's a location for it behind the center console, but i'm not sure about the S...
the light in the dash doesn't just come on when your e-brake is engaged, but since you checked everything else you should be ok...
Old Jan 10, 2007 | 03:46 PM
Slows2k's Avatar
It's not the e-brake switch, or the e-brake cable adjustment. It's the brake fluid level switch inside the master cylinder reservoir. This has happened on several S2k's. The only way the switch is sold is with a new brake master cylinder.
Old Jan 10, 2007 | 04:09 PM
Picturepro's Avatar
did you spill a coke in / on the ebrake area?
pull up the center consol and clean, maybe spray silicone as a cleaner?
Old Jan 10, 2007 | 04:13 PM
Slows2k's Avatar
I swear I'm not lying
Old Jan 10, 2007 | 04:59 PM
slanguage's Avatar
No soda spilled. Did pull up center console to see what I could find. Lubed ends of cables and the spring and the end. Also made sure the "switch" under the lever was clean and had a good contact. Also tightened the nut a little between the spring and cables. Will find out later if this worked
