Brake Noise
Old May 19, 2005 | 08:29 AM
Itr#249-rip's Avatar
Default Brake Noise
My left rear brake started making noise about 2-3 days ago, so yesterday I changed both rear brakes with oem pads. Today it is still making noise. Any suggestions or ideas?
Thanks
Old May 19, 2005 | 08:37 AM
mikegarrison's Avatar
"Making noise" could be anything. Describe it better.
Old May 19, 2005 | 08:50 AM
The noise is a grinding, screeching noise which is not heard when I first start driving but gets louder later in the ride as the car gats hotter. Eventually the noise is almost always there. When stopping it gets really loud, especially last few seconds before i come to a complete stop.
Old May 19, 2005 | 08:53 AM
SIIK2NR's Avatar
What did the pads look like when you took them off?
What did the rotors look like?
Did you resurface the rotor? You should resurface the rotor when you install new pads and make sure to use the shim grease to silence them.
If you have constant noise, sounds like you've got caliper issues. Check your calipers and brake fluid for a change of fluid.
Old May 19, 2005 | 10:38 AM
You might also have bent the dust shield. Check to see if the dust shield is rubbing on the rotor. I did that once, and it made a noise similar to what you describe.
Check to make sure the caliper flange bolts are tight.
BTW, I totally disagree with the advice that "you should resurface the rotor" whenever you change pads. In fact, except in very rare circumstances, I think you should never resurface the rotor.
Old Dec 26, 2006 | 03:33 PM
S2kSmiles's Avatar
I have a similar issue with the right rear corner on my 03 S2000.
The sound is like tool chatter with a plunk. It is RPM dependent.
Sound is audible over 15 degrees of the rotation of the rear wheel.
Given that I can
teamking
Apr 27, 2009 06:00 AM
otgixxer
Aug 22, 2006 05:36 AM
nivag
Feb 15, 2006 07:54 AM
mhs2k
Jun 18, 2004 11:23 AM
qk2000
May 20, 2004 10:06 PM
