Grinding noise when braking ?
Old Jun 17, 2004 | 05:49 AM
mhs2k's Avatar
Default Grinding noise when braking ?
Hello Everyone,
I have this "metal grinding noise" in the front of the car whenever I hit the brake, coming to a stop. I couldn't find anything stuck on or around the brake disc, and there is no bent part around the area. My car has only about 13,000 mile on it and I have never track my car. I have change from several set of wheels (16, 17, & 18 inch), I was wondering if that has anything to do with it ? I don't know if the front brake pads are worn? Thanks in advanced for your help.
Mark
Old Jun 17, 2004 | 06:23 AM
slalom44's Avatar
Top Answer: 1
If you're doing a lot of heavy braking, then it is likely that the grinding noise you describe is the wear indicator doing its job. You should check to see how much pad material is left. If there's not much left, a little tab on the outboard brake pad makes contact with the rotor, making a grinding noise. It doesn't do any damage - it's just annoying enough for you to get them checked out.
Old Jun 17, 2004 | 09:28 AM
mhs2k's Avatar
Thank you Slalom44. I'll check it out again. For some reasons, the noise went away after about 15 minutes of driving to work.
Old Jun 18, 2004 | 04:08 AM
slalom44's Avatar
Top Answer: 1
If it went away, then it is possible that you had rust on your rotors. The grinding sound will be heard until the rust is eventually swept away by the brake pads. This is common if you wash your car, and let it sit overnight before driving it.
Old Jun 18, 2004 | 11:23 AM
mhs2k's Avatar
I think you are right. I do was my car and leave it parked overnight and sometime for a few days in a row w.out driving. Thanks. I really appreciate it.
Mark
j12
Jul 28, 2010 02:04 PM
TheTownAbbott
Mar 23, 2009 03:00 PM
Itr#249-rip
Dec 26, 2006 03:33 PM
nivag
Feb 15, 2006 07:54 AM
qk2000
May 20, 2004 10:06 PM
