Brake Pad Difference?
Old Nov 18, 2006 | 12:47 PM
riokong's Avatar
Default Brake Pad Difference?
Hi,
I just got my R4S pads (AP829)in and tried to install them last night. I found that the rears fit but the fronts don't. The ears on the pads are to large and don't fit in the brackets. Has anyone experienced this?
I have a 06 did they change the pads for the 06's? Has anyone changed there 06 pads?
Is there a difference in pads from AP1-AP2?
Old Nov 18, 2006 | 02:02 PM
Gloffer's Avatar
Typically you may need to do a little grinding or filing to make the pad ears fit in the caliper slots. Just grind/file enough off to make sure the pads are able to slide freely in the slots and you'll be good. I've had to do this with one set of R4S and did NOT have to do the "customization" with one set.
PS: Make sure the raised buttons on the back of rear pads are aligned correctly with grooves in the calipers.
Old Nov 18, 2006 | 07:04 PM
mikegarrison's Avatar
No, typically you do NOT have to do that. All S2000 years use the same brake pads (except the compounds are different for AP1 and AP2 OEM pads).
829 is the right number for the fronts (537 is the number for the rears). Sounds like the R4S may be not built to the correct design or else has lousy tolerances.
Old Nov 18, 2006 | 07:47 PM
riokong's Avatar
829 is the right number for the fronts (527 is the number for the rears). Sounds like the R4S may be not built to the correct design or else has lousy tolerances.
If I was to grind off the ears it would have to be half for they are twice as thick as the oem pads. I hope thats not the little bit of grinding gloffer refered to.
I was thinking, could they have boxed the wrong pads? The pads look a little bigger too. Of course there are no cat # on the pad so no way to tell.
Are you sure that there is no difference in pads for all the years of the S2000?
I got the AP365 for the rears and those work.
Old Nov 18, 2006 | 07:58 PM
Originally Posted by riokong,Nov 18 2006, 08:47 PM
IAre you sure that there is no difference in pads for all the years of the S2000?
Yes, I'm sure. And if they follow the standardized numbering system everybody else uses, the 537 is actually correct for the rears.
Old Nov 19, 2006 | 07:14 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
There should be no signifigant grinding done at all. If it's twice as big, you have the wrong pad. They should look identical by eye.
What gloffer means is some pads come with a little too much paint or powder coat and they don't fit in the slots. Small filing is ok to make these fit, as it is important that they are not tight in the caliper brakcet.
Old Nov 19, 2006 | 07:59 AM
Ek9's Avatar
Ek9
Banned
So, it's common to have to mod the pads? I had to trim a 1/16th of an inch off the width of the pads for my civic when it had SI calipers. I was trying to figure out if I had the wrong pads or something was bent. It was several different brands of pads too. I was pretty puzzled.
It's got Acura Legend brakes now and the pads just slip into place.
Old Nov 19, 2006 | 09:47 PM
No.
Old Dec 2, 2006 | 06:19 PM
riokong's Avatar
Okay, It took a while but it has been confirmed....Portefield did pack the wrong pads into the correct box. I just got the pads and installed them.....Everything is fine and all it works great.
Old Dec 2, 2006 | 06:41 PM
Good to hear.
Mr-T
Mar 4, 2015 06:03 AM
yuning83
May 23, 2008 09:01 AM
x s2k x
May 3, 2006 09:20 PM
R2S
Jan 30, 2006 09:22 PM
WestSideBilly
Sep 4, 2001 05:46 PM
