Brake pads
Old Mar 21, 2006 | 07:16 PM
revS2k's Avatar
Unhappy Brake pads
My brakes are squeaking but how do i know if they are the front or rear brakes? I want to change them this weekend, should i just change both front & rear? Thanks guys.
Old Mar 21, 2006 | 07:23 PM
Bassem's Avatar
Look at the pad thickness. If both are marginal...change both! If not, it should be clear which ones are worn out.
Bassem
Old Mar 21, 2006 | 07:28 PM
Slows2k's Avatar
If the noise is in front of you, it's the front brakes. If the noise is behind you it's the rear brakes. If the noise is all around you it's both.
Old Mar 21, 2006 | 07:44 PM
revS2k's Avatar
hmmmmm well i guess i am not good at judging where noise comes from . ill see wich one is worn more. I didnt know if the fronts grabbed first or the rear grabbed first or if the both grab at the same time? Well ill just do what bassem said, thanks guys
Old Mar 21, 2006 | 07:59 PM
xviper's Avatar
Well, I never would have guessed.
Have you tried sticking your head out the window?
Old Mar 21, 2006 | 08:03 PM
RACER's Avatar
Old Mar 21, 2006 | 08:12 PM
revS2k's Avatar
wow........ i am just gonna stop talking lol aha
Old Mar 21, 2006 | 08:14 PM
revS2k's Avatar
Lets just pretend none of this ever happened.
Old Mar 22, 2006 | 08:25 AM
Nimbus's Avatar
Just check your pad thickness is all you need.
Old Mar 22, 2006 | 02:00 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Have someone walk beside the car at 2mph. This is very effective at pinpointing noises.
s2k_ndshit
Oct 9, 2013 01:10 PM
s2kjdm
Aug 25, 2011 10:58 PM
S2_4SHOOR
Aug 4, 2011 12:20 PM
s2k_Nut
Mar 6, 2010 08:28 AM
UKjasonm
Aug 24, 2009 09:37 AM
