Brake Problem......HELP
Old May 21, 2006 | 07:26 PM
WindchaserS2K's Avatar
Default Brake Problem......HELP
I'm not sure what I did wrong I replace the rear brake line to some SS lines and I did my best to bleeding the sys (Both rear size) and after that the Brake Padel doesn't feel the same as before, it just feel so soft and mushy(so easy to bottom out) Please Help me out here............
Old May 21, 2006 | 07:29 PM
gotswap's Avatar
Keep bleeding and make sure you keep the master cylinder full.
Old May 21, 2006 | 08:08 PM
well I guess I will try that
Old May 21, 2006 | 08:18 PM
s2kBryan916's Avatar
Very good thing to do so you dont introduce a new air buddle at the top of the system. When you open the bleed valve have steady pressure on the pedal.
Old May 21, 2006 | 08:29 PM
Shadow_S2K's Avatar
Former Sponsor
Make sure you are not pressing the brake pedal all the way down to the ground...or else you will be drawing in air also.
Old May 21, 2006 | 08:43 PM
ok got it
Old May 21, 2006 | 09:58 PM
I keeping tryin to bleed but nothing happen the damn brake padel still feel soft and mushy
Old May 21, 2006 | 10:21 PM
Shadow_S2K's Avatar
Former Sponsor
Are you pumping the brakes a few times before you open the bleader valve?
Old May 21, 2006 | 10:41 PM
jzz30's Avatar
anything leaking?
are you bleeding the front also? try that
Old May 21, 2006 | 10:44 PM
Shadow_S2K's Avatar
Former Sponsor
Hum...I hope you are bleeding all four corners...and following the correct order. You cannot just bleed the rears.
