Brake Rotor Installation
Old Nov 26, 2005 | 07:22 PM
batikan's Avatar
Default Brake Rotor Installation
My stupid brother tries to change my rotors the other day eventhough I told him we don't have the right tool. He used a regular Philips Screwdriver which didn't fit all the way in so he stripped one screw. What should I do now??? Should I try to drill it to take it out?? I don't want to damage other stuff. Also what should I use to take the rotors out??
BTW, it is only those two screws that need to be taken out to chage the rotors??
Old Nov 26, 2005 | 07:31 PM
161MPHTOPSPDS2K's Avatar
You need an impact socket with a phillips head.Should fit perfect into the screws.You turn the socket to the left while hitting it with a hammer it should break lose.The same way to tighten it back on.After removing the caliper and caliper bracket, those are the only screws holding it to the hub.Check sears.I bought mine from there and never had anyproblems after using it about 100 times!
Old Nov 27, 2005 | 03:28 AM
Lovetodrive2000's Avatar
Don't buy a "cheap" one...
I did, and broke the head of the phillips off in one of the screws.... Thought I had really screwed up that time, but the broken head jusk popped out....
Second one I bought did fine.
Old Nov 27, 2005 | 05:57 AM
centralcoastbuc's Avatar
Here is the link
http://www.sears.com/sr/javasr/product.do?...00&tab=des#tabs
Old Nov 27, 2005 | 07:21 PM
mikegarrison's Avatar
Since none of the other posts ansered the question -- yes, you may have to drill that screw out. The impact driver is a tool primarily used to keep it from getting into that position, rather than for recovering once you already have a stripped screw head.
Old Nov 27, 2005 | 07:55 PM
batikan's Avatar
do you think it is safe to do?? do you think there is a possibility that I will damage something else??
Old Nov 27, 2005 | 07:59 PM
Is drilling safe? Yes, if you do it right. Take your time and be careful. All you are trying to do is drill off the head of the screw.
Depending on how messed up things are already, the impact driver could possibly still work.
Old Nov 27, 2005 | 11:09 PM
ExOdy's Avatar
If you have access to a dremel, just dremel a slot perfect for a flat head. After dremeling the slot, use an impact driver to get the screw loose. Very easy and you can still use the screw in the future.
Old Nov 28, 2005 | 07:25 AM
Screws are cheap. If you are going to use one, use one that is not damaged.
(Me, I haven't installed those screws for a couple years now. They only hold the rotor in place when the wheel is not on.)
Old Nov 28, 2005 | 07:32 AM
pantyraider's Avatar
BTW, if you do want to replace the screws make sure you get it from Honda. I was in a bind and I got some screws from Orchard that fit but the head wasn't the same. Anyway, what happened was the wheel didn't sit flush on the rotor and created a wobble in the wheel.
So, I just run without the screws now.
