Brakes seized after disc replacement?
Hi Guys, new to the forum
I have a 2000 AP1, UK RHD
When i bought the car it drove fine with no brake related issues, parked the car up for about a month and noticed the front left brake sticking after a short drive
In the past few days i have changed to grooved rotors and EBC pads, slides on the pad holders greased and the pins are moving freely, put it all back together and after braking to firm up the pedal i now have the front right and rear left brakes stuck on...
Any ideas? is simply bleeding required in this instance or is it caliper rebuild time?
Thanks in advance
Thanks in advance
I've been on the same road. Front Right seized, took it apart, greased it etc and after 3 weeks it seized again.
Same with rear left. After that I did a complete rebuild with the original Honda Kit and its been almost 3 years with no issues
If you are interested, the part numbers are:
Front: 01463-S2A-000
Rear: 01473-S2A-000
Rear: 01473-S2A-000
if the slide pins are good u need to rebuild or replace the caliper. you can get the piston and seal on rockauto and rebuild them but if you don't feel comfortable doing it replace it. remember these are your brakes lol. I don't no of any shops that rebuild stock calipers. mostly due to the time involved and liability.
Sgt Skidmark
Jun 15, 2010 05:01 PM
