Brakes squealing
I don't know if it is the front or the rear but everytime I brake I hear a pretty distinct squeal. I have approximately 27,2xx miles on the car now. What are our OEM brakes life expectancy under conservative driving conditions? My last s2000 I had the same squealing noise so I took it to Honda and they found a rock in between the calipers. This time I don't know what it is yet because I have not yet taken the car to Honda. I haven't bleed my brakes yet either. Any advice would be very helpful.
What are some good pads to buy and where to purchase them? Should I purchase OEM pads and install them? Or should I get aftermarket pads? I believe I hear the squeal from the front so there is no need to replace the rear pads.
I had a problem like that at a premature age and comes to show that my rotors were not...don't remember the word, in other words not "flushed" I suppose and it wasn't the brake pads. So I replaced the rotors got some from ebay. 3 yrs later still no problem
Just an experience I had hope all is well.
My driver rear brake is also making a rubbing noise. The noise is always there (barely), but gets louder when I apply brake pressure. It started when I installed my slotted drilled rotors, so I assume it is related to the rotors. I hope I don't have to replace the rotor. how do I check to see if the rotor is making the noise?
*resurfaced* was the word I couldn't think of. See if that works on your rotors at a shop somewhere if that's not it I'm going with your brake pads you probably got a bad set don't quote me on that just throwin my two cents.
