Break in the 2.5L inlinepro engine
If you adjusted your fuel pressure with the vacc line intact you will have higher fuel pressure than you adjusted ie when you take the line off your fuel pressure gauge should read higher than 60psi (or whatever pressure you adjusted it at).
So you have aldready been running on higher fuel pressure anyway. Don't worry too much Juan. Hook up the AEM and injectors and wait for Sean.
Today I installed the 440 Cc injectors (using Stock ECU). Left the car ilde for a while to see if there was any leak nad evething ok. It was interesting that the S was not smoking and did not pop up a CEL code.
Tonight I going to do a short trip around the block to see if there is any fuel leak.
The 18th is tuning TIME!!!
