Break problem
Old Apr 25, 2008 | 11:13 AM
DanTheManUK's Avatar
Arrow Break problem
Hello, I hope you can help me!
Took my car out for a blat today to notice a problem.
When slowing down to a hault from about 5mph > 0mph I get a grinding noise comming from one of the back wheels.
Also when I pull away again the same grinding noise happens from 0 > 5.
When I got home I decided to do a few quick tests to find out that when I grab the back right wheel and rock it, it makes the same noise.
Also the radiant heat from the back right wheel was immense, the rest were hot like it should be, but this one wheel was seriously hot.
Any ideas on what is causing it, its like that break is sticking which is why it is getting so hot.
I cannot feel the car pulling when I let go of the wheel, so it must be minor but I still would like to get it sorted asap.
Old Apr 25, 2008 | 11:39 AM
blkwidow's Avatar
''Brake'. '
Seized caliper? I'm willing to bet on it.
Old Apr 25, 2008 | 11:45 AM
dead-bird's Avatar
Remove wheel, Inspect calapers...
Don't drive untill you do.
Old Apr 25, 2008 | 11:54 AM
How is a siezed caliper generally sorted?
Simply rebuilt or just cleaned?
Please dont say replaced
Old Apr 25, 2008 | 01:01 PM
blkwidow's Avatar
I believe you can rebuild it.
I found this.
http://www.handa-accessories.com/s2000-03.html
Scroll more then half-ways down.
Old Apr 25, 2008 | 01:04 PM
jyeung528's Avatar
to me, sounds like wheel bearing.
Old Apr 25, 2008 | 01:08 PM
blkwidow's Avatar
Take off wheel and inspect caliper. If everything lookls ok then put the wheel back on and try to rock it back and forth. If you notice any play then it's the wheel bearing.
Old Apr 25, 2008 | 03:42 PM
vfast1's Avatar
Brake pad down to the metal?
Old Apr 26, 2008 | 02:49 PM
Solved: Retracting the piston "unseized" the capier, sorted.
Old Apr 27, 2008 | 01:32 PM
SheDrivesIt's Avatar
Nahh. Hot wheel is typically brake.
mambo
Oct 21, 2015 02:40 PM
j8mie
Dec 12, 2010 04:40 AM
JsRacingS2K
Aug 11, 2009 09:14 AM
J.nguyen
Dec 4, 2008 04:40 PM
BigMeanBull
Feb 26, 2004 11:14 AM
