broken cat bolt
i was taking off my 2000 exhaust system and i broke one of the three cat bolts/studs? and i tried to beat it out but it would not budge if anyone can hel i would really appreciate it thanks
Often, if you heat the flange with a MAPP torch (propane is not as hot, acetylene is better if you have it) the expansion of the metal will allow you to hammer the bolt/stud out. Just be careful where the hot bolt lands... ;-)
Originally Posted by burton 7218,Nov 21 2008, 09:17 PM
would it be ok to just leave it would it for sure leak?
Mig or Tig weld a nut onto whats left and wind it out. If you dont have welding gear visit a local workshop.
technique is to weld through the centre of a nut onto whats left of the stud. Just be careful not to weld the stud into the flange. After the heat of welding they often wind out really easily.
