Broken Differential: What Actually Failed??
Old Dec 8, 2002 | 02:59 PM
Destiny2002's Avatar
Default Broken Differential: What Actually Failed??
For those of you who have experienced differential failure, and know what part of the system actually failed, please post here, along with the cause if you happen to know or suspect.
Thanks!
Old Dec 8, 2002 | 04:39 PM
Wesmaster's Avatar
In my first failure it's hard to tell exactly what happened in what order, but here's the story. The torque from a high RPM launch pushed the differential and ring gear "backwards" snapping the part of the housing that the bearing cap bolts go into. The bearing caps snapped in half, and the ring gear knocked a hole in the differential housing. Everything got crunched up inside and required a complete replacement.
My second failure, after adding the Kaaz differential and Comptech bearing caps, was just the pinon gear shearing in half and causing damage to the ring gear. The ring gear and pinion gear are being upgraded to a J's 4.44 and the gear set and differential housing are being cryogenically treated by One Cryo http://www.onecryo.com .
Old Dec 9, 2002 | 07:16 AM
j2k's Avatar
j2k
I had my pinon gear come apart as well.
-jason keeney
Old Dec 10, 2002 | 06:25 PM
Utah S2K's Avatar
Might want to mention the rest of your powertrain is somewhat upgraded also Wes (i.e. Supercharged).
Utah
Old Dec 10, 2002 | 07:28 PM
Wesmaster's Avatar
Originally posted by Utah S2K
(i.e. Supercharged)
I heard that the SC didn't make that much difference on an S2000.
macr88
Drivetrain
Jun 21, 2014 05:33 PM
19wrath85
Jan 21, 2011 10:42 PM
Gernby
Jun 25, 2002 08:00 AM
