Broken Lug Bolt
Old Oct 9, 2006 | 06:54 PM
AATees's Avatar
Default Broken Lug Bolt
OK, some idiot with an air wrench at a tire shop that will go nameless over-torqued my rear wheel lugs. Since I swap my tires out with R-compounds when I Auto-X (If you have tried it you must indulge ), I had to strain mightily to remove the bolts, only to rip one bolt clean off .
No problem. Off to the tire store in Mineral Wells, TX and they tried valiantly, but failed to remove the wheel hub. Nice guys, but ignorant. Not dumb, they just didn't know any more than me.
I took it to the dealership, who agreed that the hub would have to be removed and the bolt(s) pressed out/in. No problem, just $190. Then they called and said that the wheel hub had a sealed bearing which would also need to be replaced. Now its $330 plus bolts (~$10 each).
Question: I'm I being robbed or is this just another cautionary tale about not letting idiots anywhere near your car? Your responses are appreciated.
Regards,
Al
Old Oct 9, 2006 | 08:30 PM
SIIK2NR's Avatar
IMO Your being robbed. Do it yourself if you have the time and save yourself litterally hundreds of dollars.
Tim
Old Oct 9, 2006 | 09:36 PM
coop's Avatar
The wheel bearing hub has to be pressed out and should be replaced. The wheel bearing hub list for $89.00 http://www.hondaautomotiveparts.com/auto/j...gry5=REAR+BRAKE
and it takes some tools that most people don't have, axle puller, a press, 240lbs (??) torque wrench, and I believe a few others. I think for a dealer it is billed as a 2-3 hour job, took me 4 hours each wheel.
Old Oct 10, 2006 | 06:19 AM
Ek9's Avatar
Ek9
Banned
Yeah, it's not a trivial job. Every time you pull the hub apart, the bearing's supposed to be replaced. They should have told you that up front though. If they're going to pull the hub anyway, I'd have all the studs replaced at once. More than likely they've all been damaged by, the idiot with the impact wrench. The cost of the studs is trivial compared to the cost of the rest of the job.
I've done it here at my house but, my wife gave me a 20 ton press as a christmas present so, I have the tools I need.
Old Oct 11, 2006 | 02:15 PM
AATees's Avatar
Good wife . Thanks for the insight. I have authorized the dealer to proceed and will replace all of the studs.
Regards,
Al
Old Oct 11, 2006 | 02:39 PM
jeggy's Avatar
you can also take the hub out to a machine shop and have them press it out/in for you.
usually napa, carquest and some autozone have presses so they can do that.
Old Oct 11, 2006 | 03:48 PM
dhayner's Avatar
Originally Posted by AATees,Oct 11 2006, 02:15 PM
(snip) I have authorized the dealer to proceed and will replace all of the studs.
Regards,
Al
You're doing both left and right sides, correct? Anything that the mad torquer has touched.
Old Oct 11, 2006 | 05:21 PM
RT's Avatar
RT
"mad torquer"
lopez14
May 11, 2012 11:29 AM
nomadicS2k
Jul 11, 2011 08:03 AM
babowc
Dec 12, 2009 08:33 AM
zuppy51
Dec 12, 2007 09:47 AM
Deathscythe
Mar 19, 2003 10:09 PM
