Loosing power during vtec
Hey guys started to notice that while im in vtec in 1st or 2nd gear though 6500 - 7500 the vtec stops and then starts again at 7500. What could this be from. I thought that the oil may have needed changing I will try this but if thats not the problem what could it be? Thanks guys need the help.
maybe take your Vtec solenoid off and clean/ replace the filter screen. If it has any dirt or debris in the screen, it could cause a drop in oil pressure to the sensor. Only takes 2 min to do and won't cost anything to check. Worth a try.
Originally Posted by joper90,Oct 10 2006, 08:06 AM
map sensor.. mine did that.. its like it hits a flat spot in the rev range.- there are tons of threads on fixing it.. takes 5 mins and is free.
Exactly.. no reason to fool with VTEC components, do a search on MAP whack. Probably just needs contacts reseated.
Hey guys thanks for the advice I changed the oil and did the "MAP whack" and car is back to its normal kickin' @#! self. Time to go own some mustangs whos egos are too big for even there cars. haha thanks again.
