Broken seat adjuster cable
Old Nov 28, 2017 | 05:40 AM
marquardt's Avatar
Default Broken seat adjuster cable
I have a 2008 S 2000 whose driver side seat adjuster cable just broke. The seat is in the most rearward position. Any thoughts on getting to the back bolts for removal? How do I replace the seat adjuster cable. I appreciate the input.
Old Nov 28, 2017 | 04:24 PM
Hfreak's Avatar
Seat fully forward and a couple long extensions on the ratchet will make the rear bolt removal pretty easy, cable is like a bicycle or motorcycle cable and also pretty easy.
You can reach under the seat and manually pull down(or up) the release on each side but might not be that easy to get the seat fully forward, good luck.
Old Nov 29, 2017 | 01:58 PM
Chris_Lum's Avatar
it's just a wire that connects the two sides, so fab one up really quick with a clothes hanger or other wire and connect the two sides again.
zhp43867
Jul 6, 2019 10:29 AM
NikosX
Aug 20, 2009 05:11 PM
tim62
Feb 17, 2008 08:35 AM
gche37
Mar 19, 2003 05:27 AM
jcasta02
Dec 17, 2001 02:42 AM
