Bumper Crack = help
'''not sure if this is in the right topic''''
When I removed my bumper today I saw a little crack in my bumper. I am not sure if I made it or if it was already there.
The slit is underneath the bumper, where the bolts that hold the bumper to the plastic are. It is about 1 inch long. It doesn't go up on the bumper so you can't see it unleast you lie down.
Will the slit become longer ????
What to do ?
Thank you
the crack is betwen bolt number 14 and 15 on the figure 3 :
http://www.ricks2k.com/info/instructions/diffuser.pdf
What to do ?
Thank you
Well I can surely live with it ... it dosen't show.
So I drill a hole ?
good idea !
Do i drill it a little in front (leaving lets say 1-2 mm between the crack and the hole ? or do i drill a the end of the crack ?
thanks for your help !
So I drill a hole ?
good idea !
