Buying a new MAP sensor for a AP1
Old May 20, 2007 | 06:24 PM
trivium's Avatar
Banned
Default Buying a new MAP sensor for a AP1
I have 2002 AP1 and the engine has the notorious rough idle that occurs during stop and go traffic or when shifting from R to 1st gear and back, etc. I know its because the ECU is "learning" but it annoys the hell out of me. I tried doing the MAP sensor "whack" and fiddling with the connector but it hasnt gone away.
I read some where that there is a newer MAP sensor which eliminates the issues. Is this true? and would it be the same MAP sensor which comes on all newer MY s2000's ?
Old May 20, 2007 | 07:00 PM
CKit's Avatar
I think the newer MAP sensor is just the same sensor with a little zip tie to keep it snug.
Old May 20, 2007 | 07:50 PM
steven975's Avatar
yep, same flawed sensor.
If the whack isn't working it may be time for a new MAP sensor.
Is the oil level OK? The S2000 can idle rough with low oil.
Old May 20, 2007 | 08:12 PM
iam7head's Avatar
[QUOTE=steven975,May 20 2007, 07:50 PM] yep, same flawed sensor.
Old May 20, 2007 | 08:22 PM
trivium's Avatar
Banned
cleaning the IAC? How DO I do that?
Old May 20, 2007 | 08:28 PM
iam7head's Avatar
i don't want to say search, but yeah...search. not trying to be an arse, but the faq has nice picture and you'll like it with images
it's just a metal part bolt onto the driverside of the motor, you can take it out in less than 15 minture, a can of throttle body/intake manifold cleaner(5-6buck) and an old toothbrush will do it.
make sure you don't kill the rubber gasket by dipping it into the throtte body cleaner.
Old May 20, 2007 | 08:30 PM
CKit's Avatar
I thought I was having the MAP sensor problem. Bought a new one. Same problem. The throttle body and injectors were clogged, causing the problem.
Had the local lube place do the 15 min cleaning (~$60) and haven't had a problem since.
Old May 20, 2007 | 08:33 PM
CKit's Avatar
Old May 20, 2007 | 08:36 PM
iam7head's Avatar
Originally Posted by CKit,May 20 2007, 08:33 PM
nice
the throttle body cleaner i used was by valvoline synpower, same brand for injector cleaner.
and for motor, i used the OEM honda top engine cleaner
Old May 20, 2007 | 08:50 PM
trivium's Avatar
Banned
I did an extensive search but I couldnt find any thread with a detailed how to on IAC motor/valve cleaning. I need pictures too.
Help?
