Buzz from behind dash on deceleration
Old May 8, 2006 | 03:06 PM
vtec9's Avatar
Default Buzz from behind dash on deceleration
Let me preface this by saying, this is 100% definitely not clutch buzz. I have the decel clutch buzz, I can easily recognize it, and this is NOT it.
Ok here we go.. I took some back roads off home from work today so I could do some spirited driving. I hit 7-9k a couple times and I was cruising at 4-5k in lower gears. Shortly after I heard a very loud, slightly erratic, buzzing noise coming from behind the dash/cluster (NOT near the tranny) on deceleration from say 4300 to 3200 rpms. My best description of the noise is a mix between a 10ft bumble bee and a weed whacker. I heard it in 3rd and 4th gear (didn't check the others), but I highly doubt this has anything to do with the drivetrain. I know the car makes many noises, and generally I think nothing of it if I hear something slightly out of the ordinary, but this made me say ok what the F**K is that.
It could be something right near the fire wall, but it really sounded like it was inside the dash. I started the car back up about 10 minutes later, revved it a bit in the driveway, and took a quick drive but I could not reproduce the noise. Even if it never comes back, I wan't to know what it was!
Old May 8, 2006 | 03:15 PM
Fencer's Avatar
I've heard something like you've described. It ended up being the little plastic cover on the rear view mirror bracket. I was amazed that little thing could make so much noise.
Old May 8, 2006 | 03:42 PM
vtec9's Avatar
the rear view or the side mirror?
Old May 9, 2006 | 11:34 AM
Fencer's Avatar
The rear view... there's a little plastic cover on the bracket that is stuck to your windshield. It's on the '05s...I didn't think the mirror changed from model year to model year.
Old May 9, 2006 | 11:57 AM
raymo19's Avatar
I've had a buzz like that for a long time that I only heard in conjunction with the clutch buzz. I finally figured out it was coming from the passenger side visor. I placed my hand on it and the buzz stopped.
Now I just regard it as one of those little things that give the car its "charm".
Old May 9, 2006 | 12:00 PM
soozookabluS2k's Avatar
hey man i think i recently have come up with this same sound. It only happens once in a while not all the time and i prolby couldnt duplciate it if i wanted to. Id also like to find out wut it is.
Old May 9, 2006 | 04:47 PM
cdelena's Avatar
Do you still have an oil cap installed?
Old May 9, 2006 | 05:28 PM
vtec9's Avatar
I checked the oil cap. it was on tight. the noise is definitely not coming from the rear view or a visor. It's either behind the dash or from the engine bay close to the firewall. It's clearly centered in that area. It was raining today or I would have poked around more, even though I only heard the noise a few times yesterday, and zero times since.
Old May 10, 2006 | 11:12 AM
RWD_RCKT's Avatar
I had a similar noise... my Comptech intake carbon lid screws had come loose and were letting the lid rattle.
Do you have a Comptech intake?
Old May 10, 2006 | 11:18 AM
gosixers215's Avatar
Is your A/C fan on by any chance when this happens?
